Head combustion chamber re-sizing...
Old Sep 20, 2001 | 11:23 PM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
I know a head can be changed from 58cc to say, 64cc, but can you go the other way, from 64cc to 58cc? Thanks guys.
Old Sep 20, 2001 | 11:50 PM
Guest
Guest
Posts: n/a
Not realistically. Either you have to weld the chamber up (not the best idea but doable and expensive if done correctly) or you shave the crap outa the head, which I have never thought was a good idea.
Old Sep 21, 2001 | 08:49 AM
Scott_92RS's Avatar
Car: 1992 RS
Well, that sucks. I guess that is what I get for not reading the email enough. I bought a set of AFR 190's that are 74cc, and I need 64cc. I must have read the email wrong, damn I am stupid. I guess I'll just have to sell them on eBay or something. Thanks.
Old Sep 21, 2001 | 09:52 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You may want to contact AFR about an exchange.
Old Sep 21, 2001 | 10:19 AM
Scott_92RS's Avatar
Car: 1992 RS
I bought them used.
Old Sep 21, 2001 | 10:52 AM
Guest
Guest
Posts: n/a
AFR's supposedly have a thick deck that allows milling for that purpose, I for some reason thought you were talking about stock heads. I would contact them, see what they say can be milled off a 74cc head, but I'd venture a guess that somewhere around 67 would be a good place to stop.
Old Sep 21, 2001 | 11:04 AM
Scott_92RS's Avatar
Car: 1992 RS
Thanks for the help guys. I'll give AFR a call, then talk to my machinest.
Old Sep 21, 2001 | 07:41 PM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
Not to worry. Your heads can be angle milled to the desired compression. Go with a thinner head gasket if you need a little more.
www.geocities.com/dzperf
D&Z Performance
"Putting Power to the Pavement"
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
z28guy134
Sep 1, 2015 11:50 PM
