V Belt Config.
Old Jul 22, 2005 | 10:43 PM
klumb15's Avatar
V Belt Config.
at low rpms, like under 1700, one of my belts squeels like none other, and i think i might have 1 of the 2 belts on wrong...i have deleted a/c and smog, so just the alt/water pump/power steering left...i went and got 2 stock belts, and put them on, but i believe its the one going from the crank to the power steering is the one making the noise...i was thinking, maybe its not supposed to go around the crank, maybe its supposed to go around the waterpump instead...or maybe both, who knows, but if somebody could tell me the correct route, or show me a picture that'd be great...
I don't see why it squeels at lower rpms, and not at all at upper rpms...
Old Jul 22, 2005 | 10:58 PM
klumb15's Avatar
i was looking through my old pics, and i got one of the engine bay...i got it hooked up the exact same way as it was, just a single small belt going from the crank to the power steering...
so we know that is right, what else could be wrong? is there something i could maybe spray on the belt to keep it from sqeaking or something?
Old Jul 22, 2005 | 11:06 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
<img src="http://www3.telus.net/~crussel/belts.jpg">
Old Jul 23, 2005 | 09:50 AM
klumb15's Avatar
i have it like the bottom right of the three V8's there..and still squeaking...
Old Jul 23, 2005 | 11:40 AM
klumb15's Avatar
well i took the little belt off that was going around the PS and the crank, and i got a longer one and went around the crank, up around the waterpump, then around the power steering, and it worked like a charm....absolutely no squelling!!!
thanks Apeiron for the diagram....
Old Jul 23, 2005 | 12:20 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That's what the diagram shows.
MrPackstin
Oct 25, 2017 08:09 PM
sparks454
Interior Parts Wanted
Oct 18, 2015 03:18 PM
SRKLEGIN
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
kitt23
Sep 26, 2015 07:48 PM
