"Old timers"...What's wrong w/the "short" water pump?
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Why did Chevy only use this design early on? It takes up less space w/the "short" pump and "short" pullies to match.
What is the disadvantage to it...if any?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It doesn't have accessory mounting holes. It takes up less space in front of the engine, but takes up more space on the sides.
Engine: 383 Carb
Transmission: 4L60
Cars got it to 1968, trucks to 1972 and Corvettes to 1970. The Corvette kept the short pump after that until 1982, but with a larger pilot shaft.
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
As said no accessory mounting bosses. And the rest of the pulley don't align real well.
But it can be done i have an aluminum weiand SWP on my Camaro. All it takes is a little custom bracket fabrication, which i needed to do anyway.
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
not to mention that the p/s brackets are a major pain in the ***,and with the long,flimsy alt. bracket,they can be bad about slinging belts at higher rpms
They were used on v8 monzas. As I recall the monza pulleys overdrive the pump approx 40%. Thats pretty high overdrive, I always wondered if the pump didn't move as much water as a long pump.
Engine: 383 Carb
Transmission: 4L60
I doubt there is a difference. Only the exterior castings are different. Internally they're pretty much the same.
Car: 1979 Corvette
Engine: 355, TFS heads, comp 270H cam, 10.5 comp.
Transmission: 700r4/ 3:55 posi/ 2500 stall
Yes the C-3 vettes still used the short water pump and yes I do have belt slinging problems when I rev up past 6000 rpm. I will be doing a serpentine conversion soon.
evilstuie
Jan 9, 2020 08:29 PM
Chuck84TA
Jul 15, 2016 09:05 PM
Dialed_In
Aug 20, 2015 01:45 PM
