i dont know whats wrong with my car
Old Aug 3, 2005 | 12:37 AM
birry171's Avatar
Car: 1985 camaro
Engine: 1970 350
Transmission: t-5
ok this is whats goin on. i have an 85 camaro and put a 1970 el camino 350 in it. i blew a head gasket and had to replace it. now that i have it put back together its lost horsepower. i cant figure out whats wrong. i think it might be my carb but im not sure i think i have it adjusted right so i dont see what else it could be. if anyone has any info please post it. thnx
Old Aug 3, 2005 | 04:10 AM
BRobinson's Avatar
Car: 82 Camaro
Transmission: TH-350
Axle/Gears: 3.08
How hot did the engine get when the gasket blew? Did you change the oil afterwards? A little bit more info on what happened exactly (ie. were you driving and it suddenly blew on the outside, or did it start leaking down into the block, etc) and what all you did after the gasket change would help immensely.
Old Aug 3, 2005 | 06:33 AM
ede's Avatar
ede
have you rechecked timing, wires not crossed, carb adjusted right, run the valves again too much or not enough will effect preformance
Old Aug 4, 2005 | 03:10 AM
BRobinson's Avatar
Car: 82 Camaro
Axle/Gears: 3.08
Taking apart the top of your engine, just one wrong thing and you've lost the performance you had. Unless you really screw up and it won't start at all. Think back, action by action, on what exactly you did.
Just a thought, but listen at the back and front of the intake manifold. Those little 'gaskets' *HAH!* tend to be notorious for leaking after a rebuild. Did you put a little bit of RTV on the corners to help them seal? Even a little leak would hurt performance terribly.
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
fonzie85
Exterior Parts for Sale
Oct 10, 2015 10:55 PM
dhonda200
Aug 11, 2015 11:50 PM
