One quick question
Old Aug 14, 2005 | 08:27 PM
Tha_Villain's Avatar
Car: Camaro RS
Engine: 2.8 L
One quick question
Ok I've set my base timing with est wire disconnected to 0 degrees and car works very smooth. What I want to ask is why does it feel so slow and sluggish when I drive it??
Any Ideas
Old Aug 15, 2005 | 04:48 AM
ede's Avatar
ede
might be the outer ring has slipped, or it might be that zero isn't where your engine runs best
Old Aug 17, 2005 | 12:11 PM
luke4907's Avatar
Car: '89 Trans Am GTA
Engine: TPI350
Axle/Gears: BW 3.27s
is base timing on a 2.8 supposed to be set to 0*? I think TPI motors are supposed to be 6*, dunno what the 2.8 is supposed to be set to.
Old Aug 17, 2005 | 01:17 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
With everything connected, hook up your timing light and check for total advance. If you're good there, try advancing it a few degrees at a time. Do a road test each time and back off if you get preignition.
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
