Fuel delivery question
Old Aug 16, 2005 | 07:00 PM
littlekings's Avatar
Car: Dirt Street Stock oval track 2bbl
Engine: 350 w/dart iron heads and 383 w/world products sportsman II heads
Transmission: saginaw
Explain why a stock TBI fuel pump won't work with a carb. I know the pressure is too high but how high, what is the norm for a carb and what are ways around the problem.
Can I use the same fuel line on a mech pump and cut the wires to the electronic pump?
Why have I been told to use a bypass type regulator. Why the bypass and not just a regular regulator?
Old Aug 16, 2005 | 07:02 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Normal carb pressure is around 6 psi or so. Any more than that and it will flood.
A bypass regulator sends excess fuel back to the tank. A deadhead regulator will just stop the flow and will eventually kill the pump.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Vintageracer
Jan 10, 2020 05:33 PM
Infested
May 22, 2018 11:56 PM
redmaroz
Aug 16, 2015 11:40 PM
