Quick Coolant Question.
Car: 1992 Camaro RS
Axle/Gears: Stock
Okay me and my dad are flushing out the cooling system and a whole bunch of other stuff. The problem is, he just filled up the engine block with water and wants to just leave it in there, and pour some pre-mixed coolant into the radiator. I'm no pro, but I'm pretty sure this isn't the best idea.
Question: Where is the coolant drain plug on an LO3? And are they usually corroded?
Thanks a lot.
Thanks a lot.
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
actually you can lower your temps by using distilled water and an additive like water wetter.........straight tap water? oh my, too many minerals
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
You can pre- mix anti-freeze or do it as your dad did it. Just some small cars have tiny rads, and some of the old anti-freeze solutions were very thick, and didnt circulate too well, so you pre mixed with water in your bucket\watering can\ etc etc to make sure it did.
Car: 89 IrocZ
Engine: L98-ish
The lowest block drain would be where your knock sensor is.
If you're doing a flush, just pull the themostat to get everything circulating, drain from the bottom radiator hose.
But, the way your dad is doing it is okay...you'll end up with about a 50/50 mix...close enough not to worry about it IMO.
City tap water is kinda harsh, but you wouldn't be the first to run several hundred thousand miles with it
Car: 1992 Camaro RS
Axle/Gears: Stock
Okay I guess it will have to work then. I really don't give him enough credit at times. But he's messing with my baby, so I'm a bit paranoid
. Thanks a lot guys.
Car: 86 Firebird, 2002 Monte Carlo, 91 v
I run straight city tap water, no antifreeze with rust inhibitor. Runs cooler and better than it ever did before. In a couple of months I'll drain the radiator and add straight antifreeze.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Originally posted by Dirty Dave
You realize running straight anti-freeze is a bad idea? It won't give you nearly the cooling capacity of water.
Car: 1992 Camaro RS
Axle/Gears: Stock
Originally posted by Air_Adam
I think he means just to fill the rad, so it balances out with the straight water in the engine
Well we finished the little project and after a few rivers of coolant running down the garage
It's all sealed up, and running cooler than ever.Thread
