ac bracket
Old Aug 31, 2005 | 07:26 AM
gscz28's Avatar
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
ac bracket
does anyone know of an aftermarket piece for the tensioner,
you know the bracket for the ac and smog pump?
or what have you done to dress that POS up let me see some please
Old Aug 31, 2005 | 11:38 AM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Pablo did something this a while ago. He went with a standard waterpump and then added a slider to one of the alternator bolts. I've been thinking about it, but I don't know if want to change the waterpump for all that, even though its a relatively short job.
I guess I should have asked first, you are trying to remove the whole passenger side serp bracket aren't you? It supposedly worth almost 40 lbs (condensor, smog, and bracket).
Old Aug 31, 2005 | 01:45 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
SLP sells and aftermarket bracket for use whn you install headers on the car. It's says made for 82-87 though.
http://www.slponline.com/view_produc...J&BIG=30010J-1
Old Aug 31, 2005 | 02:12 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
You could convert to v-belt, and get the March parts. Or you could pony up the cash, and get the entire march system.
Old Aug 31, 2005 | 02:26 PM
NEEDforSPEED's Avatar
agin, i ditch the hole left side, all you have to do is make your alt-ajustabile https://www.thirdgen.org/techbb2/sho...hreadid=318013
Old Aug 31, 2005 | 03:17 PM
Car: 91 Camaro RS
Needforspeed, what sliders do you use?
Could you get a different direction wp and then be set without the electric wp?
Wp $25?
sliders $10?
belt $10?
a/c delete pulley $50
Now which weighs less?
Old Aug 31, 2005 | 06:28 PM
jimp2001's Avatar
Engine: LO3 305 TBI
I'm ordering the whole March TBI/TPI Serpentine setup for my new motor. I can't wait to get everything assembled and install it all.
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
meeklay812
Oct 1, 2015 03:46 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
armybyrd
Sep 26, 2015 03:37 PM
