Torque Arm too short????
Old Oct 25, 2001 | 09:37 PM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
I just swapped out my rear end and I have everything connected but the torque arm, it is about an inch short of being connected, am I missing something here?? do I need to disconect some things to get it on there?
immediate response would be good, as i'm doing this right now!!!
Old Oct 25, 2001 | 11:33 PM
Changa2's Avatar
I'm not sure if this will help or not as I'm about to swap my hind end also.
Try the following thread:
http://sethirdgen.org/10boltinstall.htm
Note that: Shocks then Tq Arm and then LCA.
Not sure, check it out.
Old Oct 26, 2001 | 03:21 PM
dans82bird's Avatar
Engine: 302
thanks man, that did help out, as i was unsure as to the order to put everything back...
Old Oct 26, 2001 | 06:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I've been through this twice, and the order I reconnected was LCAs, panhard, torque arm, springs, shocks.
The LCAs locate the rear front-to-back; the panhard side-to-side; the torque arm rotationally; and the springs and shocks were put in last for safety reasons.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 CC system w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" catback, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
tglennon11
Sep 23, 2015 05:30 PM
Nick McCardle
Sep 10, 2015 08:36 PM
luvofjah
Sep 10, 2015 10:41 AM
rudolphschenker
Sep 4, 2015 02:41 AM
