problems with battery
i have a 83 camaro z28. it has the lg4 engine. in the cold the engine wont start. i think it has something to do with my battery. when i turn the key the engine will turn over for about 10 seconds and then the battery will die, but then when i jump it it starts right up. ive talkied to some peole and they said that the battery cells might be dead and that it might be affecting the cold cranking amps or that i might not have enough cold cranking amps in the first place. so please tell me what i can do to see whats wrong with it before i go bye a new battery.
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
If the battery is sealed there really isn't too much that you can do. However, if the battery has two covers on the top, you can pry them up and check the levels of the water. If the water level is too low you should be able to just top it off with some distilled water. The battery is probably just shot and should be replaced.
-=-Mike
1989 RS.. 355, Hypereutectic pistons, double roller cam, double roller timing chain, accel wires, blue streak cap and rotor, rapidfire plugs, chevy caprice 350 chip, 200* fan switch, 3 angle valve job, 3 inch cat-back exhaust, 3 core radiator, 3.73 gearing with POSI.
-=-Mike
Street Lethal
Apr 30, 2019 12:14 PM
db057
Aug 11, 2015 10:11 PM
