car pooping out?? am i misfiring or is tranny about to go??
Ok, i was coming back from the Home Depot, and i was on the highway going about 45 MPH and i noticed that the car was kinda jerking a little bit, kinda felt like the Torque Convertor was unlocking and locking, so i gave it a little gas which usualy cures it, well this time it didn't, it kept jerking, and the RPM's were fluctuating 200+-. so i let off the gas, and it does the same thing, except at a lower RPM range, with the T.Q. still locked. so i put it in netruel and the RPMS still did that, and u could feel it. but however, when i came to a stop, and put it in netruel, it idled fine. It does this jerking think in both 3rd and OD.
I replaced the coolent temp sensor today, but im almost 100% sure i hooked up everythign back correctly. is that sensor next to the coolent temp sensor the Knock Sensor?
anyone got any clues weather its my Tranny or just missfiring? No codes as of yet.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
http://www.geocities.com/david_angel_16
- David
top
- David
- David
Car: 91 camaro
Engine: 383
Not sure which coolant sensor you replaced, but your knock sensor is in the block right by the starter. As for tranny or misfire, I think it's a good sign that the rpms fluctuate in neutral because if it were your tranny I don't think you'd have that problem in neutral. Sounds more like a misfire. But maybe you should post this in the tranny section too.
91 Z28
Come see The Vicious...
91 Z28
Car: 91 RS
You know what you might want to do, you might want to check out your fuel pressure coming from the fuel pump, or replace your in line fuel filter, sometimes when it is dirty your car will only act up in higher RPM's. Although my TBI car shoots less pressure than your TPI car, mine was doing the same thing, until i changed out the fuel filter. When you take off the filter turn it the opposite direction and tap it on a white piece of paper, and watch all the junk just fall out of it. hope this can help you in any way at all, good luck
Dan
Dan
hey i have a question i was just about to post that is just like this one, except a little different, mine is doing the same thing, except it does it idling, city driving. where ever it wants to. it doesnt do it when its cool, and when it starts up, it acts like the carb is trying to adjust the idle constantly (its a CC Qjet), varys within like 100 rpm. any ideas for me? its a 350 with a 262 cam, pefromer intake, nothing tooo hot.
Location: All over China, Iowa, and San Luis Obispo, CA
1 Post
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: 5.7 TPI, LG4
Transmission: 700R4, 700R4
Axle/Gears: 3.27, 2.73
Same damn problem here, what's up with that? Maybe the Afghan's are tainting the fuel supply.
If anyone has "the cure," lemme know.
86 Z28
LG4 rebuilt, yet tired again
700R4 (father just broke it)
Have 400 short block waiting for a rebuild still planning it out
Edelbrock catback
86 Z28
Edelbrock catback
Car: 91 RS
I am telling you, your fuel pump dies slowly, and you will never even know it or believe me until you check it out. But before you check the fuel pressure, check the fuel filter and that should help a whole lot. When was the last time you changed your fuel filter, or your fuel pump??
well, not sure about filter. but im getting 44 PSI.
- David
- David
well i decided to change filter, worked like a charm, dont know why i didnt change it when i had the whole engine out and the carb just sittin there, but oh well. i was pretty sure it wasnt my fuel pump as i replaced it just a year ago. thanks guys, for answering my question even though it was someone elses question, what a deal.
Car: 1987 Trans Am
Axle/Gears: 10 Bolt SLP Torsen, 3.73 ratio
<font face="Verdana, Arial" size="2">Originally posted by breathment:
</font>
</font>
Corry
Edit: Under normal operationg conditions (nothing blocked, no vac lines disconnected)it should be around 44 psi (just thrown in to avoid confusion)
[This message has been edited by Corry (edited October 29, 2001).]
Linson
08-21-2015 02:12 PM
