What size are my valves??
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
I need to know what size valves my stock 83 T/A with the LG4 has. I know for a fact the motor has never been apart, so they are original. I got another 305 motor for free. It has 1.85 valve heads w/ casting #14022601. They are of an 84 casting year. THX
1983 T-top Trans Am. All stock (for now) LG4/auto/3.73 posi. 70,000 original miles. SLOWLY going through a Knight Rider conversion. (it will be done one of these years)
Bset of 15.79@86mph 2.16 60ft
1963 Dodge Dart drag car. 360/904/4.88
Best of 10.94@120.44mph
Transmission: 4L80E/4L80E
1.84" intake, 1.50" exhaust. Should be exactly the same as the '84 engine.
Why are you asking? If you're thinking of putting the '84 heads on the '83 engine, there's no difference. If you're thinking of having the '84 heads worked over for performance, then don't bother - get a set of World Products S/R Torquer 305 heads and have them pocket ported (at least). 1.94"/1.50" valves, better combustion chamber design, better flow, screw-in rocker studs, thicker deck - no good reason for sticking with factory heads (and those who know more than me say use 416 castings if working over factory heads).
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ4 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (ported World 305 heads, Crane PowerMax cam, Hooker 2055 headers, 3" Catco cat & 3" catback w/Flowmaster, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
