Real Quick Question Help Me Out
Old Sep 24, 2005 | 12:15 AM
87'z28gpse's Avatar
Car: 1987 Iroc
Before I start I just want to let everyone know I searched and didn't find my answer. I just picked up a set of 16" 91-92 z28 wheels for my 92' RS. Right now the car has the stock 15" rims with 235/60/15 tires and drum brakes. My question is for the rear wheels can I bolt the 16" rims up without a spacer or do I have to have a spacer for the rear wheels??? By the way the tires on the 16" rims are 245/50/16. I know the fronts will bolt up without a problem. Any help is greatly appreciated!!!
Old Sep 24, 2005 | 02:34 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
They should bolt up just fine as far as I know. All 92 wheels are supposed to be interchangeable (all thitd gens too I believe)
Old Sep 24, 2005 | 07:05 AM
justlearning's Avatar
Car: 91 camaro 305 tbi
Engine: 305 tbi l03
but the wheels are different for front and back if u didnt know that they should say on the inside of the rim
Old Sep 24, 2005 | 09:59 AM
87'z28gpse's Avatar
Car: 1987 Iroc
I know the wheels are different for the front and back, I just need to know about the spacers for the rear...
Old Sep 24, 2005 | 04:01 PM
vrtc350's Avatar
Car: 81 Corvette
Engine: 355, ported vortec heads
My rs has the 16" rims and it has a small spacer on the rear. I think it is 1/8"
Old Sep 24, 2005 | 05:48 PM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
spacers
I did the same thing on my T/A. I used a set of 2front/2rear 16" formula wheels and it looks as if I need to put at least a one inch spacer on the rears. I also have front tires that are rubbing just a little on the front portion of the inner fenders.
The car is at the body shop being restored right now. But when I get it back at the end of Oct. I am going to look into a set of bolt on 1 1/4 inch hub eccentric spacers. Unless I bolted the wheels on backasswards, don't think I did, but I might not have taken my meds that day. lol!
Old Sep 24, 2005 | 06:24 PM
87'z28gpse's Avatar
Car: 1987 Iroc
Well I put the rims on today and didn't have a problem with them rubbing. I am going to go ahead and get the spacers anyway to be safe. Thanks for all the help
Old Sep 24, 2005 | 10:30 PM
vrtc350's Avatar
Car: 81 Corvette
How did they fit up front. Just curious because of the huge offset difference between the front and rear. Or did the 15" have the same offset? I know the older ones don't.
Old Sep 24, 2005 | 10:44 PM
87'z28gpse's Avatar
Car: 1987 Iroc
Everything fit up perfect, the car looks like it left the factory with the 16" wheels on it. I will take a pic tomorrow and post it up.
Old Sep 24, 2005 | 11:12 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I think the "spacer" that came from the factory was just there to keep the hot drums from welding themselves to the aluminum wheels.
I could be wrong, but with as thin as they are I can't imagine they're actually providing any space behind the wheel.
Old Sep 25, 2005 | 09:43 AM
vrtc350's Avatar
Car: 81 Corvette
So the same offset is there with the 15" wheels? I thought that the front was even with the rear end if it came with 15" wheels.
That could be possible, I know the spacer itself isn't much.
Old Oct 1, 2005 | 01:47 PM
my3rdgen's Avatar
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Mine originally had the 15 inch wheels and the offset was the same all the way around.
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
