Alternator
Old Nov 12, 2001 | 10:06 AM
FAST85Z28's Avatar
Alternator
How long does this take to put in a 1985 Camaro Z28, and about how hard is the work? I have never messed with this car by myself yet.. I hate working with belts though..But this time I have money for the part. But no extra spending cash to put it on for me...
Old Nov 12, 2001 | 11:34 AM
Xenodrgn's Avatar
It's -really- easy.... Like... really...
There are 3 mounting bolts... one goes through the bottom, loosen that one first... and then there are two on the top that clamp the thing in place. Loosen the one in the back, then the one in the front... the alt should now swing freely..., detach the belt. Unplug the one connector on the alt and unscrew the bolt on the other connector and undo the wires, they may be under a red cap. Make sure nothing else is hooked up, undo the bolts and slide out the old alt...
Install is the reverse of uninstall... but you might wanna connect the plug-in connector first, that can be ackward putting in once it's all bolted up... Make sure the belt is good, if it is make sure it's tight, I mean tight... I used a screwdriver for leverage to make sure it was tight... You should also clean all the connectors of residue and white powdery stuff from the connections at the alt and the battery.. also check your grounds while you're at it...
That should do it... It sounds like alot, but it's cake. Good luck.
1985 Camaro SC - 2.8L, auto.
C'mon, spin 'em for papa...
http://www.xenodrgn.f2s.com/Frontright.jpg
Old Nov 12, 2001 | 11:52 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I'm not the mechanically inclined and I have done it several times, not sure how long it took, I would say 1/2 hr.
"Putting any amount of money into a RICE BURNER is like wiping your a$$ with a turd. "
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Nov 12, 2001 | 01:58 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I'm not mechanical at all and it takes me about 10 minutes. It's about at the same difficulty level as replacing your air filter, except that it involves tools.
OBTW, on the 85 it's even easier than the other post says... only 2 bolts plus the wires...
ICON Motorsports
Old Nov 12, 2001 | 10:53 PM
FAST85Z28's Avatar
It was easier then I thought it would be... took me exactly like 10-15 mins... very simple...It was on the same skill level as changing the air filter...
~1985 Camaro Z28~
V8,305,700R4,K&N Edlebrock Air Filter,& MSD 8.5MM Super conductor Wires,
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
