Engine Running Rough
Old Oct 20, 2005 | 09:15 PM
earlesimers's Avatar
Car: '91 Camaro RS
Engine: 3.1 V6
i got a 91 v6 3.1 with automatic trans. its having some problems, sometime i have to crank it for about 10 sec. before it will start. then i can hear a little bit of a miss in the motor. then when i drive it the motor starts reving up and down like its trying to die. then when i come to a stop it smooths out but it idles a little high. oh, and it smells like its running very rich, very high emmision smelling.
here is a list of what has been replaced so far.
(by a mechanic)
plugs, wires, distrib. & cap & rotor.
(by me)
pvc valve, airfilter.
Old Oct 21, 2005 | 02:46 PM
pellmanm's Avatar
Car: 1989 GTA
Engine: 383 Fuel Injected
Transmission: Pro-Street 700-R4 by Pro-built
Axle/Gears: Moser 12 bolt w/posi
Sounds like you need to re-set your timing, iac, and then tps, in that order. There are articles on this site that have all the information on how to do each one. Read them all carefully. See what difference that makes, then go from there.
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
camaroken83
Aug 10, 2015 11:35 AM
