where is everyone mounting their tranny coolers?
Old Nov 18, 2001 | 11:21 PM
breathment's Avatar
Will it fit in front of the radiator? If not where is the best place to put it?
And im posting this hear instead of tranny board cause i know there are people here with tranny coolers that never goto the tranny board
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
Old Nov 18, 2001 | 11:34 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
I put mine in the very front. Attached it to the front of the AC cooler. Works great for me.
1986 Trans AM
355 TPI
4 Wheel Disc Brakes
9 bolt Borg Warner Rear (2.77's....oh joy) :P
6" rods, approx. 9.7:1 Compression, Stock TPI (soon to be ported), 24#/hr LTI injectors (cleaned and flowmatched by Cruizin Performance), Hedman Shorty Headers, 3" exhaust with 80 series flowmaster, SBC 993 heads completely redone and modified for 1.6 RR, 1.52 RR (for now), Comp Cams XE262-14 TPI Cam, Holley AFPR, TPIS airfoil, MSD wires, MSD 6-AL Ignition, Hypertech 53,000 volt coil.
Track times to come.
Old Nov 19, 2001 | 12:02 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Mine is in front as well, fits fine.
"Putting any amount of money into a RICE BURNER is like wiping your a$$ with a turd. "
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Nov 19, 2001 | 01:59 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Mine is out front, at the upper passenger side. It was attached originally to the a/c condensor (with the mounting straps). Since I removed my a/c, it's now attached to my radiator- same spot, using a Summit trans cooler re-mount kit (new mounting straps).
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Nov 19, 2001 | 07:40 PM
breathment's Avatar
what kinda hoses? steel or rubber? or braided?
and do yall bypass the radiator?
- David
[This message has been edited by breathment (edited November 19, 2001).]
Old Nov 19, 2001 | 07:51 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
On the 85 mine is outside where the rest of the guys have thiers. On my 82 that still has A/C I have mine on the inside facing the fan almost. Both bypass the radiator (helps keep the the water cooler in the summer) and run on 3/8th rubber line.
SSC
85 Camaro, 355/400 "drag car" current DD 13.1@ 101mph on its last season run.
Plans: Possibly add N20 for next season.
82 Firbird, rebuilt 355 for it and slaped a 700r4 in. The 700r4 crapped out so back to the tb350
Old Nov 19, 2001 | 08:06 PM
breathment's Avatar
do u guys with it mounted in front have A\C?? it looks like there is enough room but i wanna make sure. also, which coolers do yall recomend, could i go up to pep boys and just pick up one of theirs?
- David
Old Nov 19, 2001 | 08:19 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
<font face="Verdana, Arial" size="2">Originally posted by breathment:
</font>
The only reason I dident put the fbird on the front is because the condenser was pinching the lines a bit too much for my liking and the cooler I got for that would not fit behing the X straps.
Any A/M cooler will do the job, find which one is rated for your car and step up one or two sizes depending on what you think will fit.
SSC
Bubbajones_ya
Jul 6, 2024 08:32 PM
scottmoyer
Sep 7, 2015 07:06 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
