How to adjust door windows?
Old Nov 26, 2001 | 11:46 AM
Greg's Avatar
Car: 89 Formula T-Top
Engine: 388 MiniramII
I tried to follow the Hayes repair manual but that didn't work. I replaced the T-top weatherstripping and the window doesn't seem to line up to the back upper corner part on the weatherstripping. It looks like I need to adjust the window to arc in more. Help me please.
'89 Formula 383 TPI
Old Nov 26, 2001 | 11:54 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If it's the vertical part of the weatherstrip, like where the window seals to the T-top itself but doesn't land on the weatherstrip properly, it's alot easier to adjust that out than it is to move the window. You can just bend the metal piece that's behind it outward.
ICON Motorsports
Old Nov 26, 2001 | 12:16 PM
Greg's Avatar
that is the spot but I also need to move the whole window back. It is hitting the front weatherstripping too hard.
'89 Formula 383 TPI
Old Nov 26, 2001 | 05:04 PM
Enkil's Avatar
There's a technical article on this website.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Nov 26, 2001 | 05:35 PM
ede's Avatar
ede
remove the door panel there are 2 felt tipped guides and 2 travel stops (i think). you get the panel off and they're easy to see and understand waht you need to do (all adjustable) to make the window move to where you need it to. good luck.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
hepcat620
Sep 2, 2015 11:51 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
