is it time to replace the iginition module?
Old Nov 27, 2001 | 03:12 PM
daniel dekay's Avatar
my car died the other night while driving. up until then ive noticed no problems with starting and driving. i read some posts in the archives, and without a ohm meter or any diagnostic materials i just decided to replace the coil. it started right up, then after a short rev to get the voltage up a little the car died and i couldnt get her started back up.
so now that ive replaced the ignition coil, is the ignition module the next thing to replace? how hard of a swap is this?
thanks
daniel
86 camaro cpe(dont laugh)has 92z28 body kit with GTS covers, new red paint and a killer stereo. 2 amps, 8 speakers, disc changer, custom install with subs coming by the end of the summer. gm 350,TES headers, flowmaster cat back, performer manifold, TCI converter, jet chip, kn with dual snorkel cleaner. and she still passed the sniffer!
"Cal Poly SLO is the shi#"
Old Nov 27, 2001 | 03:38 PM
88firebird305's Avatar
I know on my 305 tbi it took me a whole of 10 mins to do it. I just took off distributor cap removed the two screws hold in the mod. unpluged the wires connected to it, loaded the bottom with dieletric greess, dont forget that or it will overheat screwed it back in put cap on started right up.
Old Nov 27, 2001 | 05:47 PM
irocbsa's Avatar
Takes about 15 mins to do. Still having problems huh?? Usually a bad module will produce a check engine light but not in all circumstances. YOu done any of that routine maintenance yet (plugs, wires, O2 sensor, coolant temperature sensor)???
bsa
Old Nov 27, 2001 | 06:14 PM
breathment's Avatar
you can get the ignition module tested at O'Reillys. That is if u like that store, which i don't, but thats another story!
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
Old Nov 27, 2001 | 07:22 PM
as far as routine maitenence goes, the last time the plugs cap and rotor were replaced was about 14 months ago.
well thats some good news then, 15 minutes, i was reading the manual and it wanted me to remove the distributor and all that jazz, but i all i have to do is remove the cap right? i was kinda afraid to remove the dist. cuz i didnt want to mess the timing up, and being down here at school without any of my tools (i.e timing light and what not) i was just gonna take it in. but now i will give it a shot.
thx guys
daniel
Old Nov 28, 2001 | 04:02 PM
irocbsa's Avatar
The distributor definitely does not need to come out.
bsa
Old Nov 28, 2001 | 06:08 PM
well i just finsihed replacing the ignition module and it did the same thing when i replaced the coil. it started briefly then died and i couldnt get it started again. since those two are ruled out, what else could this be?
i need the car pretty soon, i think my roomattes are getting tired of driving me to and fro the parts store.
thanks
daniel
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
justin57
Aug 20, 2015 07:05 PM
