v-belt question
v-belt question
ok i need to know whut accessories the two belts in front of and in back of the main drive belt in my v-belt system run. i no this sounds dumb, i should know this, but this is my frst v-belt TA, my other had the serpentine. so if someonce could help m,e out it would be a great help thanks, oh and my engine is a 305 TPI.
Transmission: 4L80E/4L80E
In front is the A.I.R. pump. In back are AC and power steering. I'm out of town so can't go out and look at the car, but if memory serves, the PS is in front of the AC, with the AC belt going around the PS pulley as well.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
In case you're wondering, although I have an '86 LG4, I also have an '87 LB9 engine with all accessories, and it's exactly the same.
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Five7 is pretty close, but I'll add some info:
All F-body (which are the same for G-bodies and some trucks) v-belt setups are the same for 305s and 350s. They go, in order from the front (farthest from engine) to the back (closest to engine):
A.I.R pump belt (driven off Water Pump)
Alternator belt (ribbed belt, also goes on crank and water pump)
A/C belt (also goes on crank, water pump, and P/S pump)
Power Steering belt (goes only on crank and P/S pump)
All but the alternator belt are v-belts. Check my website and the pics on the bottom of the engine page for somewhat of a picture of the pulleys.
Hope that helps!!
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Hope that helps!!
1987 GTA L98 MD8
My GTA
Okay, my AC compressor is off for the time being, I have the PS belt in the front grove of the pump pulley. Besides, I'm 1500 miles away from my car right not. Memory not always 100% reliable. The Regal rental is completely different from the Camaro, no good going out to look at it.
A mind is a terrible thing to waste.
Or, is that, a waist is a terrible thing to mind?
Never mind.
Listen to Matt.
Good night...
Never mind.
Listen to Matt.
Good night...
Guest
Posts: n/a
It doesnt matter on his 86 but the earlier setups (I think pre 84, err... lets say 84 and earlier) used a V-belt for the alternator as well.
I usually dont use the PS belt, only on wet days sitting in a puddle of water have I ever had a problem with not having it in there, and I am not really sure if it would have mattered anyway. If you do use it, adjust the belts right otherwise it will have a tendency to squeal.
[This message has been edited by madmax (edited November 30, 2001).]
<font face="Verdana, Arial" size="2">Originally posted by five7kid:
Never mind.
Listen to Matt.
Good night...</font>
Never mind.
Listen to Matt.
1987 GTA L98 MD8
My GTA
