Whoops, set the timing when the car was in park...
Old Dec 4, 2001 | 04:49 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
I set the timing when the car was in park, i was told to do it when it was in D so the engine is under some load, any truth to this? I set the timing to 8* BTDC, stock is 6*(L98) if i should've done it in D what do u think my base timing is at?
*89 Trans Am GTA
*Moderator at www.transamgta.com
To hell with the GM vs Ford war. We must unite, as brothers to fight the plague that is overtaking the world...RICE
Tony
Old Dec 4, 2001 | 04:53 PM
toosloz's Avatar
if you set it in drive...can i watch?
you'll be chasing your car
do it in neutral
84z28HO
355
open element/k&n
m5/hurst billet plus shifter
83 z28 fiberglass hood
10bolt w/3:42posi
gm aluminum driveshaft
performer intake
performer 600cfm carb
accel 8mm wires
adjustable thermostat switch
160 stat
gta rims
gts blackouts
s.s rear control arms
s.s panhard rod
s.s subframe connectors
98 camaro rear springs,shocks
98 z28 leather seats
95 camaro rear view mirror
"wonderbar"
4th gen z28 tips
14.3@95mph
http://www.geocities.com/toosloz/84camaroz28.html
Old Dec 4, 2001 | 04:58 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
My Dad and brother always checked the timing with the car in P. N would be the same as P anyways.
2 Tickets to game= $250
Gas= $20
Sitting 20ft. from MJ= Priceless
'86 IROC T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK HEADERS Hooker CatBack
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Dec 4, 2001 | 04:59 PM
breathment's Avatar
well since u are setting the BASE timming....
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
Old Dec 4, 2001 | 05:00 PM
hy-po-ny's Avatar
conventional wisdom would lead one to believe that the car would have to be stationary in order for you to set the base ignition timing. putting the car in drive, hence the words "under load", might cuase problems as you sit in the direct path of the soon to be moving vehicle. no intentions to flame you but i gotta say that question was best left to yourself. End of discussion-
L8
1976 mustang
4 cylinder 4 speed
2.3 liter
looking for a camaro!
[This message has been edited by hy-po-ny (edited December 04, 2001).]
Old Dec 4, 2001 | 05:57 PM
irocbsa's Avatar
I'm sorry man, no flames intended, but I just got done reading the "Common Repair Myths" post before this and I'm laughing my *** off right now at the thought of you running *** down the street after your car with a wrench in your hand. Hey, If you can't laugh at yourself, who can you laugh at?
bsa
Old Dec 4, 2001 | 06:25 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Ive hard of setting the timing in D (With the Ebrake and a friend with his foot on the brake) but Ive not ventures to try it nor have had a need to. You will be fine.
SSC
Old Dec 4, 2001 | 07:46 PM
ronterry's Avatar
Car: '94 Corvette
Dosn't it depend on the specs. I mean if the manual says 8 degrees at 800RPM, then that would be park.
I think you would have problems if you where setting the timing at high idle say greater then a 1000RPMs.
I don't even think the wieghts would move any between 650 & 800 RPM's.
Hell, since we are flaming a little. Wouldn't a total timing measurment be better -- say 3000RPM under load.
Ron
'82 Trans Am
'81 Camaro Z-28
'94 Vette LT1 Coupe
'00 Impala LS
Old Dec 4, 2001 | 08:08 PM
fly89gta's Avatar
Car: 2018 Camaro SS
um, of course someone would be on the brake, on the gas a bit bringing the rpms up to around a grand, i'm just saying i've heard some people setting the timing this way...did i say i did it that way? no...so no flames!
hy-po-ny um, STFU how's that sound? you of all people giving advice, the same person who called TTA's white trash and actually thought his 2.4 multicolored mustang had a chance in a race
Old Dec 4, 2001 | 08:09 PM
fly89gta's Avatar
Car: 2018 Camaro SS
<font face="Verdana, Arial" size="2">Originally posted by SSC:
SSC
</font>
thank you for NOT jumping on me, see i'm not the only one that has heard this guys!
Old Dec 4, 2001 | 09:42 PM
HighHopes85's Avatar
<font face="Verdana, Arial" size="2">Originally posted by ronterry:
</font>
Well, since we are flaming, whatareyathinkin? No weights and springs in a HEI for an L98. The EST module takes care of it all. -Matt-
specialized
Jun 18, 2022 09:26 AM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
jharrison5
Aug 19, 2015 05:53 PM
