fuel problem
Old Nov 27, 2005 | 01:41 PM
kickasscamaro's Avatar
Car: 1985 camaro z28
Engine: 305 tpi
fuel problem
car wont start, i can hear the fuel pump running and i smell gas under the hood when cranking, but when i press down on the schrader valve nothing at all comes out. i turn the key about a hundred times back and fourth(can hear fuel pump running) and still nothing. sometimes the fuel pump will keep running about 20sec after turning the key off. checked for leaks and cant find any.
any ideas?
new fuel filter about a month ago
Old Nov 27, 2005 | 09:25 PM
Firebat's Avatar
buy and install a fuel pressure gauge, see if you have enough fuel pressure, if not, get a new fuel pump. Make sure you're getting spark. Check fuses. Thats where i would start.
Old Nov 27, 2005 | 09:32 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
The first thing to check on a no start case is the fuel pressure. Buy yourself a good fuel pressure gauge, install it, and have someone turn the engine over while you read the fuel pressure.
I have a fuel pressure gauge installed full time under the hood.
You should read about 43.5 psi at the fuel rail with the vacuum line removed and plugged. This is the vacuum line between the plenum and the fuel pressure regulator.
Old Nov 29, 2005 | 02:59 PM
Engine: 305 tpi
have spark, checked all fuses everything ok. could a faulty fuel pump relay cause the pump to still run but, not get enough pressure to start?
Old Nov 29, 2005 | 06:58 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
So what is the fuel pressure after key on?
Old Nov 29, 2005 | 07:46 PM
Engine: 305 tpi
still havent checked my poor *** will have to wait to friday to buy 1
Old Nov 29, 2005 | 07:50 PM
Engine: 305 tpi
could a relay work half ***? or is it all or nothing with them?
Old Nov 29, 2005 | 10:54 PM
Firebat's Avatar
a relay wouldn't. but a bad electrical connection might. I kind of doubt it though since you can hear the fuel pump.
Old Dec 1, 2005 | 11:58 PM
jeez's Avatar
Car: 1986 Chevy Camaro 2.8
Engine: 2.8 V6
I have the same problem with my camaro. what kind of fuel pressure gauges can i buy ? like auto meter ?? or are there cheaper ones i can get. ALso, i would like to install it in my engine compartment too, is it difficult. and how would i do it
thanks
Old Dec 2, 2005 | 01:01 AM
Enyce31082's Avatar
Car: 1987 Pontiac Trans Am
yeah i def have the same problem on a 91 firebird v6. I hear the fuel pump. Took the top manifold off checked the fuel lines all the way to the manifold everything seem s in order and stumped. Car was running last night i had it on for 45 min and now i started it this morning and it started and then just pupped out and wouldnt turn back on. At first it sounded like the battery cause my volt meter was really low but it not it bc there a new one in now and still doing the same thing. Checked all fuses to the fuel pump and there all fine. Im planning on getting a new motor anyway i just need more time with this motor till im ready. Anyone got any ideas i d really appreciate it cause im outta ideas and so are 3 others here. I m probably gonna feel stupid when i find out what it is but oh well.
Old Dec 5, 2005 | 11:37 PM
Firebat's Avatar
i like summitracing.com for car parts like gauges. A parts store should have fuel gauges also. Check out jegs.com also.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
