do pulleys really work?
Old Dec 22, 2005 | 10:05 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
I have a 92 RS 5.0 t-5...I alos have a $25 credit ihave to use from summit bu the end of the month and was thinking of getting a set of under drive pulleys...motorvation i believe..but before i spring for them i was wondering what gains or loses to expect...thanks
Old Dec 22, 2005 | 10:24 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I don't think they're worth it.
They just lower the speed you turn other accessories, so for example, slow down the speed you spin your water pump, drawback is less cooling, but since you're using less power spinning it, you gain a few HP. Usually they're mild enough not to slow down your accessories to the point you notice, and then of course don't give much power.
I'd say save that for when you've max out the power of the engine, and you're looking to squeeze the last tiny bit of efficiency out of it. Best used on a new honda or something that's already at top efficiency. I think there's better ways to get power out of your engine.
Old Dec 24, 2005 | 09:28 AM
whoaru99's Avatar
Car: 1991 Z28 w/G92
Engine: 5.7 TPI
I put ud pulley on my Z and "think" it made a difference, but I've never run my car on a track to check times so if it really did or not I can't say for sure. I just did it as part of the standard bolt-on goodies like cat-back, supercoil, K&N's, open up plug gap, etc.
One thing I can say is if you cruise around town at night (lights on, maybe A/C on, etc) I would think twice because of the alternator running slower puts out less charge. I had problems with this so I put on a smaller alternator pulley and that helped some. Still, the battery charge will start to drop if doing much stoplight-to-stoplight driving.
Also, I'm on the second alternator (and it's now making noise too) and I think it's because of the heavy charging it's trying to do at the lower RPM driving around town. These are "quality" alternators - GM original and GM reman. Yeah, two alts doesn't sound too bad at first, but the car has only 35K miles....
Old Dec 25, 2005 | 06:02 PM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
I bought the BBK underdrive pulleys for my setup. Of course, I had no other choise, I have no other pulleys to put on. I've heard yes and no's, if you just want to have something to do on your car, then get em. Take it to dyno and let us know!
Only $120, $95 with your credit.
If your saving (seriously) for a power adder, might want to hold out on the pulleys and get some chrome BLING BLING!
evilstuie
Jan 9, 2020 08:29 PM
Navy8125
Aug 22, 2015 07:13 PM
mcquigg
Aug 13, 2015 02:26 PM
Street Lethal
Aug 12, 2015 11:33 AM
