Pushrod length
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Pushrod length
Stock for a Hyd roller is 7.200. I found and picked up a set of TF Chrome Moly 7.250 one pieces for 12 bucks new on ebay. Would this work well in basically a standard rebuild? Will .050 make a huge differance?
Car: 1987 Iroc, 1987 MCSS TPI
Engine: 5.7L
Transmission: 700R4 in both
Yes, it will make a difference. It can seriously screw up your rocker geometry. This can cause valve train issues. You should use the correct length, if you don't know the correct length, you can buy a special length checker push rod and check your set-up.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You're only guessing what you need. Technically the only engine that needs stock length pushrods is a stock engine with nothing more than a basic rebuild and no machine work.
The only way to know if an overlength pushrod will work is to install them and check the valve train geometry or buy a checking pushrod and see exactly what length is needed.
wigmobile
Feb 26, 2025 02:56 PM
