LB9 Timing question
Car: '89 5spd GTA
Engine: 305(LB9) TPI
Axle/Gears: Borg-Warner 3.42
LB9 Timing question
Thinking of adjusting my timing and need some advice. All of the current mods are listed in my sig and I do not have any software to view the ecm, but can I adjust the timing via the dist cap and make a positve difference in power? If so, approxiametely how much and to what degree?
Transmission: 4L80E/4L80E
Typically. Disconnect the ECM wire, start engine, with engine at idle determine current "base" timing. Adjust it 2 degrees more advanced, reconnect ECM wire, see how it runs. Advance it again 2 more degrees, see how it runs. When it gets worse with more advance, back it down to where it was better.
Car: '89 5spd GTA
Thanks five 7,
It may sound stupid, but which ecm connector? The one at the battery?
