Vacuum for Brakes
Car: 1986 Olds Cutlass Supreme
Transmission: 200-4R
Axle/Gears: good question...
Vacuum for Brakes
Since my cam dosent make a lot of vacuum, I put in a vacuum reservoir and it helped, but the brakes still werent too good. Well since its winter rebuild time Ive put on a Holley DP and some hotter plugs, and its like a completely different motor now. I roll into the throttle in first gear, roast the tires, shift into second, still burnin them up, shift into third, they start to grab but just cant hold onto it and still keep spinning.
But the wierd part is my brakes are now good. I slammed on them cuz thats what I was used to having to do, but this time it brought the car to a quick stop. I didnt think just changing to a better carb would help the vacuum out. Whats the explanation for this sudden, but good change?
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Somehow, you are either producing a lot more vacuum or you are doing a lot of leg press's at the gym. Also, maybe the problem was due to an air bubble getting caught somewhere.
The cars running better in every way possible, so Im happy
I also just remembered I switched the vacuum line for the brakes from the intake to the carb. I didnt think it would make any difference. Mabey it did
86CamaroDan
Sep 29, 2015 10:08 PM
Night rider327
Sep 2, 2015 04:17 AM
