NO more ECM
Car: 84 Firebird Trans Am
Engine: 305 4bbl HO
Transmission: 700-R4, 3.73 rear
NO more ECM
stock 84 TA L69....
i need a list of parts to take the engine off the computer and what i need to do....i would like to get this done now so i can just swap the engine later on
You'll need a 4MV or other non-CCC carburetor, a mechanical/vacuum advance distributor, and some means to operate the TCC in the transmission and the electric cooling fan (I believe the L69 had an electric fan, right?).
Transmission: 4L80E/4L80E
The radiator fan is controlled by a temp switch & relay, not the computer.
Any particular reason you want to go through this downgrade?
Engine: 305 4bbl HO
You can run the CC system on a 383. Check out these magazine articles from the TGO home page
https://www.thirdgen.org/newdesign/a.../rebirth.shtml
https://www.thirdgen.org/newdesign/a...rebirth2.shtml
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Even if you went with a non CC carb, i'd keep the electronic ignition and control it either with an accel ignition controller, or an EFI ecm and a map sensor.
-- Joe
-- Joe
Engine: 305 4bbl HO
so is there anything i can do now to make it more ready later on...and will anything i could do now make a difference
Have you done anything to upgrade the ignition like module & coil? Subframe connectors, poly suspension bushings, etc.?
Engine: 305 4bbl HO
The stock module & coil tend to start dying off at around 4500 RPMs.
efiguy
Sep 27, 2015 01:30 PM
