Question on Performance build... options i have
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
I was wondering if i could run a breather on each valve cover and no PCV and have no problems with oil leaks or what have you...
My carb has one provision for PCV or Brake booster and i'd rather stop... or could i run a "T" fitting on the PCV and brake booster to that one provision???
Car: '88 IROC-Z medium orange metallic
You want to run a PCV system, especially on the street. I have a breather on one side and a PCV on the other. Vacuum comes from the carb baseplate and is "teed" off to go to the brake booster.
Car: 1991 Camaro RS
Engine: 357cid
Thanks GUYS... expect smokey burnout pics and flamethrower pics when it's done
Transmission: 4L80E/4L80E
"Location: Kissimmee, FL" = high humidity.
If you don't "purge" the crankcase, you're going to build up moisture in the engine. Having two vents doesn't cut it, because they are both at the same pressure.
As stated, use a PCV valve.
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
There is an awesome thread on the argument of PCV. I think it is called "PCV or no PCV."
