Head Milling - Alignment?
Old Jan 25, 2006 | 11:45 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I have a question about milling a set of heads.
If I had a set of heads shaved down around .020" from stock, would I run into alignment problems for the intake manifold? Any other problems this could cause?
Old Jan 26, 2006 | 06:44 AM
ede's Avatar
ede
shouldn't be a problem untill you get near .030
Old Jan 26, 2006 | 01:46 PM
Air_Adam's Avatar
So I wouldn't have to touch the intake surfaces if I'm only cutting .020?
Old Jan 26, 2006 | 05:23 PM
Air_Adam's Avatar
Anyone?
Old Feb 5, 2006 | 11:03 PM
zrated57's Avatar
I wouldn't think so, but have you tried reinstalling the intake after the mill?
Old Feb 6, 2006 | 01:41 AM
Air_Adam's Avatar
I haven't put this engine together yet. I'd be shaving the heads to get them down from 68cc chambers to 64cc to raise the compression to where I want it.
Old Feb 6, 2006 | 02:15 AM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
I think that as long as the intake manifold edge doesn't rest directly on the china wall all will be fine. I just put my manifold back on, and the silicon bead is pretty thick, even after I torqued the manifold bolts. Certainly much thicker than .060
Magman
Sep 12, 2015 10:43 PM
z28guy134
Sep 1, 2015 11:50 PM
383backinblack
Aug 15, 2015 06:36 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
