Carb'd 350 convert to EFI
What do I need to do to make this work? I think the block is from the 70s and is carbed and running in my buddies '83 Z28 (chevyrumble83), what is needed to make this work with EFI?
An EFI setup would be a good start. That would include the intake, throttle body, sensors, fuel system, ECM, and wiring. Not too much else really. Of course, how well it would work, would depend on exactly what it is, like what cam it has in it above all; and your tuning skills.
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
The only EFI sensor that goes in the block is/are the knock sensor and maybe the oil pressure sensor/switch and both of those will have provisions (KS being the blocks pass. drain plug). So as far as the block goes, nothing really needed to do or anything.
The rest of the sensors really depends on what intake and system you run.
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
