Mechanical dizzy drawbacks
Old Mar 10, 2006 | 05:10 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Axle/Gears: Ford 9" 3.70
I would do a search, but as everyone knows there having problems with it. I googled it, but couldn't find an answer. Basically, I found a carb with a proform main body, which does not have a vacuum source for spark advance. I don't wanna drill the intake. So what are the disadvantages of using my vacuum dizzy as a mechanical distributor on a car that is street driven? I'm guessing I'm gonna have to mess with the springs, which is fine with me because I've done it before.
Old Mar 10, 2006 | 10:37 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
If you know how to set it up you'll be fine. Plan on losing some mileage though. I've had to use a starter retard box on a couple customers cars recently. The motors liked a lot of total advance, but then the base was too much and the starter kicked.
Old Mar 10, 2006 | 10:49 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The Proform mainbody doesn't have provision for ported vacuum, but you can still use the manifold vacuum port on the throttle body.
Old Mar 11, 2006 | 08:41 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
If you don't have a vacuum advance, you'll need to put in more initial timing, which may (as mentioned above) require a retard box to get it started.
Your gas milage will go way down driving on the street at part throttle cruising. WOT performance will be the same. I ran a straight mechanical distributor for awhile....and I switched back to a vacuum advance. Gas prices are too high nowadays!
Lbibb
May 5, 2016 12:00 AM
school boy
Oct 22, 2015 11:47 AM
sjorgens
Oct 1, 2015 07:54 PM
mfp189
Sep 27, 2015 09:25 AM
