zinc screw?
Car: 1985 camaro z28
Engine: 305 tpi
zinc screw?
i lost 1 of the little screws holding the fuel pressure regulator cover on. i took a a trip to every hardware store there is around here, and none of them had any with that fine of threads. while i was searching threw my house, i found a zinc screw that fits, and was wondereing if that type of material would fine?
Car: 88 Iroc Vert/ 1980 Z28
Engine: 305 TPI/ 350
Transmission: 700R4/ TH350
Axle/Gears: 2.73posi/ 3.08 Open
Same thing happened to me, but I haven't found a replacement. I went to 3 different nut & bolt wholesalers and they say it's some sort of weird automotive thread. I don't know what I am going to do. I was thinking of drilling and tapping a new thread??
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
huh? zinc plated screws are extremely common, but I have no idea what this screw looks like, that holds the fuel pressure regulator cover on...?
Got a pic of the screw? Wouldn't GM have it?
Engine: 305 tpi
most zinc screws i believe are made for wood. the factory screw is tempered steel, and is a bastard to drill threw. no i dont have a pic
RedLeader289
May 28, 2019 01:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
