Engine math
Old Mar 26, 2006 | 12:17 PM
Blackhawk355's Avatar
Car: 1989 Firebird
Engine: N2O 355CID
Engine math
ok, whats the formula for figuring lift with larger rocker arms, say like 1.6s or so. and is there a formula for figuring pushrod length?
Old Mar 26, 2006 | 12:35 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
You can't figure pushrod length. Best bet is to start with the stock length and go from there. Get a pushrod checker.
Regarding the lift with different rockers here is the deal. If you know the lift of the cam lobe you multiply by either 1.5 or 1.6 depending on your rocker ratio. If the lobe is .320 than multiplying by 1.5 would equal .480 lift. Multiplying by 1.6 would give you .512 lift.
If you know the lift with a 1.5 rocker than divide the lift by 1.5 to give you the lobe lift. Than you can multiply that result with the rocker ratio you will be installing. Say the lift is 5.30 with a 1.5 rocker. Than dividing 5.30 by 1.5 equals .353". Multiply .353 with 1.6 and you get .565". Those are just some examples.
Old Mar 26, 2006 | 05:38 PM
Car: 1989 Firebird
Engine: N2O 355CID
i already have the checkers, i was seeing if there was an easier way of doing it. i appreciate the response, thanks man
Old Mar 26, 2006 | 06:39 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Multiply the valve lift by 1.6/1.5=1.06667.
Old Mar 26, 2006 | 08:47 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
Don't take shortcuts or guess at pushrod length.All it will do is cost you more in intake gaskets,replacing wadded up pushrods,and frustration.Don't ask me how I know
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
Jake_92RS
Aug 17, 2015 09:42 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
