sensor
Old Mar 30, 2006 | 10:44 AM
88ragtop's Avatar
Car: 88 sport coupe convert
Engine: 305 tb
Transmission: auto
sensor
I'm replacing my starter and I noticed a sensor that goes into the eng block right in front of the starter. What is this? I would like to replace it while I got the starter out. Also I put a socket to it and I'm truning counter-clockwise but it won't loosing. Any advice.
Old Mar 30, 2006 | 11:15 AM
M&M_GTA88's Avatar
Car: 1988 GTA
Engine: 383 Stroker L98 TPI
Transmission: 700 R4 w/ B&M Shift Kit
Axle/Gears: Stock BW LS 9 Bolt with 3.27 gears
It's the Knock Sensor.
Try a big wrench and some penetrating oil.
If you don't have the right size wrench you should be able to get a cresent wrench on it with the starter out.
Old Mar 30, 2006 | 11:26 AM
88ragtop's Avatar
Engine: 305 tb
Transmission: auto
Thanks M&M. What does the sensor do? Knock as in a ping. I am getting some ping and I use premium gas.
Old Mar 30, 2006 | 01:09 PM
DLV555's Avatar
Car: 1987 Monte Carlo SS
Engine: 400 SBC
Transmission: 200-4R
Axle/Gears: 4.10
If it senses a knock or ping it commands the ESC module (or ECM) to retard the timing until the knock goes away. It will then slowly bring the timing back up.
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
