Code 33 and code 36
Code 33 and code 36
For the last few weeks I would get a SES light while driving that would affect the idle and just run rough. Once I shut the car off it would reset and be fine. Today I was going home and something different happened. It started running real rough, and shut down. Before I could give it gas with no problem, now when I hit the gas, it stalls. Now the car isn't running at all. It will start, run with a real rough idle, and stall out. It dies anytime you hit the gas. I'm getting a code 33 and 36. Any help would be appreciated! Thanks,
FBird
FBird
Car: '86 Z28, '91 RS
Engine: 305ci, 305ci
Transmission: TH200c (no kidding), TH700r4
Axle/Gears: 2.73, 2.73
my haynes says that 33 is a "MAP sensor" problem.
"Check the vaccum hoses from the MAP sensor. Check the electrical connectionsa t teh ECM. replace the Map sensor."
sorry code 36 isnt in here. there is some reasource around the site if you look around.
Car: 88 Camaro
Engine: L98 350
I'd check the fuel pressure first. Fuel filter or pump going bad will cause a lot of false trouble codes to pop up since the ECM is seeing conditions that aren't within spec.
