Knock sensor wire help
Old Apr 15, 2006 | 12:07 PM
87camaro kid's Avatar
Car: 1987 Z28
how are you suposed to tell the diffrence between the knock sensor wire and the fan switch wire, they both have the same connector?
Old Apr 16, 2006 | 10:21 AM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
Axle/Gears: 9", 3.50
Color is your best bet. Either check a helms manual (which is a must have) or go to the spark control module which should be located next to the brake booster on a bracket on the firewall. find the wire color that matches the one on the knock sensor connetctor. In my 85 it was blue. I don't know if it's the same in 87.
Old Apr 16, 2006 | 05:48 PM
Car: 1987 Z28
the ESC has a black and a white wire coming out of it and the knock and fan wire is black and the other is white so that doesnt help and its not in the manual what color it is
Old Apr 16, 2006 | 05:58 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
With key on, and a/c off, ground the wires one at a time - the one for the fan should make the fan come on when grounded, if I remember correctly.
Caspar
Jun 19, 2016 11:19 PM
bamaboy0323
Sep 3, 2015 06:07 AM
db057
Aug 22, 2015 08:17 PM
gwade12
Aug 8, 2015 08:17 AM
