starter wont fit
Car: 1987 iroc z
Engine: 355 dart platinum 215cc heads
Transmission: <<BLOWN UP TH400>>
Axle/Gears: 10 bolt 4.11's
starter wont fit
ok i have a problem with a starter its a 75 block i tryed to put a 74 corvette starter on it with a 168 tooth flexplate but the problem is that without any shims the starter is still to far away from the block almost 3 paper clips inbetween the teeth of the starter and flexplate. now i heard that there is a special starter i can get for this or i can file a starter down so it would raise it up more. are these my only choices or is there anymore thanks.
Car: 1986 Camaro
Engine: 355 HSR
Transmission: TH-700R4
Axle/Gears: 10 bolt 4:11 posi
Starter problem
If you want to continue using the 75 block, you may have to use a Truck starter, thats what I had to do. The NAPA part number was 246-4795. (I think) You can check online at www.napaonline.com just look it up for a 75 chevrolet 1/2 ton truck.
Street Lethal
Apr 30, 2019 12:14 PM
mhatfield 14
Oct 24, 2015 07:48 AM
