Base timing?
Old May 16, 2006 | 06:50 PM
slickfbody's Avatar
Car: 91 camaro z28
Engine: 350 modified
Transmission: 700R4 modified
Base timing?
Was wondering what people ran their base timing to? I had 6 degrees for the longest time, but someone suggested to run 12 , 14 degrees timing. I have a stock L98 with aluminum edelbrock heads, hsr , 58mm tb, 30lbs injectors, comp cam 266h-r14, 1-5/8 headers, 3inch exhaust.
Old May 16, 2006 | 07:32 PM
CEP89's Avatar
Car: 89' IROCZ
Engine: 5.7 L98
I have to use 0 because of all the advance my chip throws at it, to keep it from detonating. The trick is to learn to read your spark plugs and add as much advance as possible without detonation.
Vintageracer
Jan 10, 2020 05:33 PM
z28_AJ
Aug 27, 2015 08:59 PM
eddie jr
Aug 25, 2015 06:52 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
