New heads, need adj. procedure, please
Car: Chev,350/700R4 600EDL.
Engine: 350 chevy 4bolt Main
I just scored some newly worked camel hump heads 462 castings (small chamber 64cc 194 intake 150 exhaust) for my new crate motor:
Part Number: 12499529 Camshaft duration (@.050 in) 222° intake / 222° exhaust
Engine type: Chevy small-block V-8 Cylinder heads: iron; 76 cc chambers
Displacement (cu in): 350 Valve size (in): 1.94 intake / 1.50 exhaust
Bore x stroke (in) 4.00 x 3.48 Compression ratio: 8.5:1
Block: cast iron with 4-bolt main caps Rocker arms: stamped steel
Crankshaft: nodular iron Rocker arm ratio: 1.5:1
Connecting rods: powdered metal steel Recommended fuel: 87 octane
Pistons: cast aluminum Ignition timing: 34° total BTDC
Camshaft type: hydraulic flat tappet Maximum rpm: 5100
Camshaft lift (in): 450 intake / .460 exhaust
Can anyone please give me the cylinder head torque sequence?
I also need the instructions or procedure for setting up and adjusting my valves.
Any links, photos, diagrams or instructions would be greatly appreciated.
92projectcamaro
Jan 18, 2016 08:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
