9 Bolt Covers
Old May 18, 2006 | 07:51 AM
Joker's Avatar
On Probation
Car: 87 Pont Firebird
Engine: 305 Carb
9 Bolt Covers
Am I just not looking for the right description on a 9 Bolt Cover? I can't seem to find any 9 Bolt Chrome Covers for my 87 Pont, Diskbrakes, 3.27. I see lots of 10 bolt. Anyone know where I can find a 9 Bolt cover?
Old May 18, 2006 | 08:47 AM
smokin91rs's Avatar
Car: 91 camaro rs
Transmission: t5
cover
check out taperformance.com i seen one one there, it's on the home page not sure on price
Old May 18, 2006 | 08:53 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Thats one of the drawbacks of having the 9bolt...
Parts are few and far between and buying them also requires bending over and taking it between the legs...
Old May 18, 2006 | 08:57 AM
Chrome covers are worthless. Negatively worthwhile, in fact; since they invariably rust and look like hammered elephant plop within about a month. A painted or PCed stock one looks far better over the long term.
If you want something that actually does something useful rather than just impress the shallow-minded people who are easily distracted by the shiny things along the path, get a TA Performance cast-aluminum girdle cover. It actually strengthens the rear end instead of merely absorbing your money and looking like an 8-yr-old kid's plaything that got left out in the rain.
Old May 18, 2006 | 09:46 AM
chesterfield's Avatar
Car: Pontiac
Does that assessment carry over to chrome valve covers, air cleaners, timing chain covers, etc.?
Old May 18, 2006 | 10:00 AM
Draw your own conclusions. I'll give you a hint though: you won't find any chrome gewgaws on my car.
Old May 18, 2006 | 11:41 AM
Joker's Avatar
On Probation
Engine: 305 Carb
Bad Manners
Boy you ask for some friendly advise and your get these Bad Manned (Senior too) response. Do like your mother always told you, "If you don't have something nice to say, don;t say anything at all." And you moderators should be slamming these guys for their aggressive natures. There non-productive responses. This is a USER Friendly forum.
Thanks to those who had helpful suggestions.
P.S.
I've had a car photo'ed for Car Craft have you (w/Chrome).
Thanks,
Old May 18, 2006 | 12:05 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
good advice, in a pleasant or unpleasant form is good advice. Suck it up and learn something new eh?
A chrome cover, which will get rain puddles, and rocks etc, will do nothing but look nice (for a short time period). Definately get a thick aluminum girdle to add strength. I think TA performance is the only company making them for the 9 bolts though... Those thick AL covers look pretty cool too, IMHO, I have one on my 10 bolt.
FWIW I like my chrome tall valve covers, not like they take a lot of stress or see a lot of rain or elements...
Old May 18, 2006 | 12:07 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Their right about the chrome cover...
Spend your money on something that looks cool and has function (girdle)
Old May 18, 2006 | 01:05 PM
Joker's Avatar
On Probation
Engine: 305 Carb
I will be getting a nice Alum one with extra (more fulid space). But again way to aggressive responses. Don't get a Customer Service Job, wouldn't last long.
thanks,
Old May 18, 2006 | 09:06 PM
Vader's Avatar
IUNNO. Ever deal with the "customer service" at the DMV? I always feel "serviced" after walking out of there...
Besides the pitting, rusting, cracking, peeling, and general finish failures of chromed "goodies" they are frequently thinner stampings than the stock pieces. That presents its own set of problems. That said, I've run chromed timing covers and rocker covers on engines resurrected as cores since they're cheaper/easier to get than good quality painted parts. I've also paid for it later by dealing with sealing and clearance problems.
Everybody fight nicely, please.
Old May 18, 2006 | 09:28 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
From what I understand chrome parts tend to keep the heat in. So I would not use chrome valve covers, rear end cover, transmission pan or an oil pan as examples.
Old May 18, 2006 | 10:07 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
P.S.
Thanks,
Don't let Sofa get to you.He knows all the secrets and is an authority on all.But,and anyone correct me if I'm wrong,he's running a stock 305.I run into guys like him in the pits all the time.They rode to the dragstrip with their buddy because their Cavalier broke down,but they can sure tell you how to go faster.
Old May 18, 2006 | 11:32 PM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
Not really. He has a pretty impressive little engine considering the very few mods he has done to it, which if I recall correctly is nothing more than a full 3" exhaust with headers and a much hotter cam.
Old May 19, 2006 | 08:44 PM
Irockz's Avatar
It don't take much to impress you,does it?
Old May 19, 2006 | 08:50 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Whether the advice is tactful or not, it's still good advice. Chrome diff covers are worthless. As was brought up, go with a cast aluminum or whatnot. I personally dislike chrome....but to each their own. I'd rather the sleeper look (my engine paint scheme is flat/semi-gloss black)
Old May 19, 2006 | 10:17 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Don't listen to that pathethic-bench-racer-wannbe sofakindom.
He knows nothing. He has not been there nor has he done that.
Chrome is cool.
Just take your's off and have it chromed. Problem solved.
Money well spent. You now have a shiny piece in an area of your car that only about 1/4th of it can be seen...while laying on the ground under the car.
You should accent it with a neon light.
You are sofakingdom
Frozer!!!
Jan 19, 2024 04:55 PM
1Aauto
Sponsored Vendors
Nov 23, 2015 02:17 PM
86White_T/A305
Aug 17, 2015 12:16 AM
blackd-out z28
Aug 15, 2015 08:18 PM
