Casting number help.
Old May 19, 2006 | 01:44 PM
rubbermanZ28's Avatar
Car: 84 Z28
Engine: 355c.i.
Transmission: Turbo 350, w/shift kit
Im trying to figure out some info on the 350 i have in my camaro. It has all been rebuilt but id like some specs on My heads and block. Ill give you the number i have. There are a bunch i wasnt sure which ones you need.
Block:
GM20 3970610 The 6 could be a zero im not sure, but it looks like a 6.
Heads. This is from under the valve cover.
Drivers side head:Gm18t
Passenger:A126
333882
GM25
Any info on this would be great, stock HP, what it came from anything. THanks
Old May 19, 2006 | 01:53 PM
It's a 0, not a 6.
Very very very common 4" bore block from the 70s, maybe THE most common one. Came in cars, trucks, vans, boats, and everything else. Was used in everything from 69 Z28 302s to phone company vans, and everything in between.
Typical smogger heads. They came on the mighty 165 HP 350s of the mid 70s among other things. Nothing with over 185 HP though that I can recall. A126 = the 12th day of the Ath (1st, Jan) month, in a year ending in 6 (probably 76). That might be the most common SBC head casting in existence.
So you've got a bunch of very usual SBC stuff. Nothing out of hte ordinary in any way.
Impossible to guess how much power you're making, without knowing alot more about other things (pistons, cam, head work, exhaust, etc.). However, most likely, not more than 240 HP.
No way to know what any of it came from. Well, I take that back: it came from a GM product. No way to know whether it was a car or truck, what kind of car, whether any of it was underneath a 2- or a 4-barrel carb, etc. Not that any of that makes the slightest difference now.
Old May 19, 2006 | 01:58 PM
Car: 84 Z28
Engine: 355c.i.
Ok Thanks very much for the info. Just what i wanted to know.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Racerx974
Sep 19, 2015 10:16 AM
355tpipickup
Sep 13, 2015 11:35 PM
Springster
Sep 13, 2015 01:38 PM
john204481
Sep 7, 2015 03:22 PM
