Help Car died while coming to a stoplight
Old Jun 14, 2006 | 10:50 AM
IrS89IROC's Avatar
Car: 89 IROC-Z
Engine: 355 L98
Transmission: 2.77 700R4 Auto
My car was running great yesterday and as i was coming to a stop for a stoplight my car died. I checked just about everything i could at the side of the road and everything looked good except im getting no spark whatsoever at the plugs, coil or anything. Also i noticed that everytime i try to crank the car the tachometer doesnt show anything. My tachometer has always shown like 500 rpms when cranking the car. This morning i put in a new coil and still the same problem. Im at a loss as where to look next. This is my daily driver so i can not get to work and need to get this running. Car is a 89 350TPI freshly rebuilt to a 355. Im still running MAF
Old Jun 14, 2006 | 10:59 AM
Ignition module
Just change it out, "testing" it is not very conclusive
Old Jun 14, 2006 | 11:29 AM
super89irocz's Avatar
I had the same problem with my 89 camaro, I changed almost every electronic part, then figured out it was my ECM. No it runs great. Good luck
Old Jun 14, 2006 | 11:33 AM
ECM failure = very very rare
It's the ignition module
Just change it out, it's cheap and easy
Old Jun 14, 2006 | 03:59 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
I'll second the Ignition Module.
Go with AC Delco. Stay away from Accel. I've had their IM's die on me a couple times.
Old Jun 14, 2006 | 05:21 PM
pg29's Avatar
Car: 88 GTA
yep my ignition module left me stranded a couple of weeks ago as well. it seems the voltage regulator in the alternator blew and blew up my ignition module with it. the ignition module is an easy part to replace. Part Source even tested my old one to verify that it was bad.
Old Jun 14, 2006 | 09:52 PM
IrS89IROC's Avatar
Car: 89 IROC-Z
Engine: 355 L98
Thanks for the help after the first reply i went and got an ignition module i was gonna get the ac delco but it wasnt in stock so i got the GP sorensen one. I was skeptical about the accel so i got the cheaper GP sorensen. PLus it had a liftetime warranty. It fixed the problem. Well now the car got a new MSD coil also.
Wade787b
Sep 29, 2015 01:15 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
TheExaminer
Aug 26, 2015 04:59 PM
