headlights
Old Jun 20, 2006 | 07:31 PM
steve87iroc's Avatar
Car: 1987 iroc z
Engine: 355 dart platinum 215cc heads
Transmission: <<BLOWN UP TH400>>
Axle/Gears: 10 bolt 4.11's
headlights
ok when all my lights are off my turn signals work fine but once i turn the lights on the right green turn signal light in the car stays on and turn signals dont work. the left headlight works but the right is very dim. when i turn my brights on the left works but the right is very dim also. the yellow turn signal on the right of the car is dim to. what could this be.
Old Jun 20, 2006 | 07:33 PM
Loose, corroded, or broken ground connection on the right.
Follow the black wire away from the headlight, you'll find it.
Old Jun 21, 2006 | 03:44 PM
Car: 1987 iroc z
ya loose ground forgot to tighting it back up when i took the fan relay off thanks.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
