relay testing
Old Jun 25, 2006 | 05:47 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
relay testing
my 85 camaro wont run, fuel pump not priming. the fuel pump relay is make a lot of noise? is there anyway of testing the relay, without buying one? (not to much money laying around, if u know wat i mean).
Old Jun 25, 2006 | 06:44 PM
WaaX's Avatar
Car: 1985 IROC
Engine: 350 TPI (block was swapped)
Transmission: 700r4 w/corvette servo
Axle/Gears: no idea
I dont know exactly how its done but I remember that you can jump some wires on the relay to power up the fuel pump, that way youre basically bypassing the relay to diagnose whats wrong.
I dont know what wires you have to jump.. anyone care to chime in?
Old Jun 25, 2006 | 07:40 PM
jstrdn90rs's Avatar
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
On my 90 next to the main wiring harness where it comes out of the drivers side firewall there is a pigtail connector just tangling there.it should be right next to the relay.If you power up or supply power to the it ...you will by-pass the relay...anyway..relays are cheap mine was 10 bucks..If you have an electric fan relay it should use the same, one might try and swap the two?..
PurelyPMD
May 5, 2016 04:57 PM
BumpaD82
Feb 26, 2016 02:57 PM
85cmroz28
Oct 4, 2015 09:44 PM
Johnoooooo
Sep 22, 2015 08:55 AM
sahlomonic
Sep 20, 2015 07:15 PM
