clunk when braking
Old Jun 28, 2006 | 02:40 AM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
clunk when braking
1991 camaro rs, 3.1L 700R4 auto
i hit the brake, I hear clunk from left front side.
the brake works fine, just gives me this annoying sound.
my brake pads are new, rotor resurfaced recently also.
I torqued my tires really tight(in right sequence)
but without torque wrench. I just used normal wrench and really tightened up.
im not sure what this psosibly do to my brake, but is this a possibility I warped something?
sometime after i park my car, i see something slightly dripping, near my left tires.
couldnt id the fluid but since it looks like black,
is it brake fluid leaking? my master cylinder's still full though.
its kinda loud and getting annoying
any is appreciated
thanks!
Old Jun 28, 2006 | 02:55 AM
thefightback's Avatar
Car: 86 Z28
Engine: '90 350 TPI
Transmission: T700
i had the same thing - turns out my front left shock was leaking and i needed a lot more suspension repairs than that!
Old Jun 28, 2006 | 02:57 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
most likely the pad retaining clip has come loose and it's the backside pad hitting the front of the caliper when you hit the brakes.
Old Jun 28, 2006 | 03:02 AM
sogabe's Avatar
Engine: 3.1L
my shocks are new also.. so hopefully its not my shocks.
87CIZ, if what ur saying is true
will that explain the little leak of fluids too?
so will I need like a new caliper? or can i just open the whole thing up and
tighten it up or something?
thanks!!!
Old Jun 28, 2006 | 07:15 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
If the clip's come loose you'll be able to slide the pad around in the caliper while it's mounted. If it stays in place you're good. The clunk could be a number of suspension related things. Bad shock mount, shock, suspension linkage, sway bar mount, etc.
If you're not comfortable checking everything yourself (or can't find it), take it to an alignment shop for an inspection. They should charge you a basic rate, tell you what's wrong, give you an estimate then you can decide if you want to fix it yourself or not.
Find out where the fluid is coming from. If it drips overnight place something clean under it (cardboard, whatever) then trace it to the source in the morning. It could be power steering fluid, engine oil, strut oil or brake fluid on the left side.
Old Jun 28, 2006 | 03:41 PM
sogabe's Avatar
Engine: 3.1L
thanks naf.
the drip is very slight, and only noticable after I park my car
after driving. it doesnt happen overnight.
I did check my sway bar end link and its in place.
my shocks are new but I dont know how worn my shock mount is(didnt know that thing wears out)
balljoints are new, and all my brake's been serviced recently too
so kinda disappoints me I still have problem again..
I think ill take it to an alignment shop, thanks!
F-body driver
Mar 6, 2023 11:44 AM
dbrochard
Sep 19, 2015 08:13 PM
Ragtop Man
Sep 12, 2015 12:23 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
