cant find the fuel filter
Old Jul 6, 2006 | 06:18 PM
grifdog02's Avatar
i feel like such a tool for asking but i got to know where is the fuel filter on an 88 305 tpi?
Old Jul 6, 2006 | 06:46 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Drivers side, its in the area in front of the left rear tire. It's a little smaller than a soda can and is held in with a bracket with one bolt, I believe. Just a tad smaller than a soda can, same shape. Look for the fuel lines leading to it.
Edit: Also, be careful if you are replacing the filter, the fittings commonly rust together, and you risk breaking a line. If they are rusted on, soak them with a rust penetrant, such as PBblaster.
Old Jul 6, 2006 | 07:22 PM
j dezzy's Avatar
Car: 87 TA
yeah. it's right up on the frame rail. tight squeeze.
Old Jul 6, 2006 | 09:29 PM
grifdog02's Avatar
thanks guys i will check tommarrow
Old Jul 6, 2006 | 09:37 PM
Stevo's Avatar
Car: Pair of 92 Z28s
use flare wrenches if you have em, and soak in PB blaster...
On my gf's car i kinked the line, its not fun to replace fuel line in the winter either...
Old Jul 6, 2006 | 09:43 PM
j dezzy's Avatar
Car: 87 TA
Old Jul 6, 2006 | 11:27 PM
What exactly is a flare wrench and what does it do?
Old Jul 7, 2006 | 09:01 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
It's kind of like an "almost" box wrench, except it has a slit for the line to go through.. Lets you grab more of the fastener on line fittings..
Old Jul 7, 2006 | 11:16 AM
Ah, I gotchya.
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
