2 questions
Old Jul 11, 2006 | 08:48 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
2 questions
i have a 91 305 tbi. first, i am throwing a code 33, do i have a map or maf sensor and where is it at?
second, my idle is really high, stock tach reads 3000, also the tb is dumping fuel into it, you can see it splashing fuel out as it hits the butterfly's.
would these to be inter-related? or do i just have two different problems?
Old Jul 12, 2006 | 08:46 AM
Vader's Avatar
Your car has a MAP sensor, and you need to verify the accuracy of the dash mounted tach
Old Jul 12, 2006 | 09:56 AM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
IIRC, stock TBI's had a problem with fuel pooling on the throttleblade with prolonged idle....that may be what youre talking about.
Not exactly sure where your map sensor is, theyre usually mounted on the firewall or the intake manifold. It'll be a small box with a connector, and a small vacuum line running to it from the manifold.
Old Jul 12, 2006 | 07:20 PM
one more question. i set my timing with a vacuum leak going on, i since fixed the leak, would this make my idle go up? if i readjust my timing will that help it?
Old Jul 12, 2006 | 09:20 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If it was a vacuum advance distributor, then that would throw off your setting. If you have TBI as your profile says, then you have a computer controlled distributor. The computer would have adjusted to the vacuum leak, and then adjusted again once you fixed it.
Old Jul 13, 2006 | 08:53 PM
what other reasons would my idle be so high?
Old Jul 13, 2006 | 09:16 PM
Toxinz's Avatar
Car: 92 camaro
Engine: 355
Have you rechecked your timming. It sounds like it's way off.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
