wierd problem starting..
Old Jul 11, 2006 | 09:02 PM
xklipze's Avatar
So if I use the Key starting the car.. You will most likely hear some sort of voltage electricution type noise, and it takes the engine super long to turn over....
However i installed a Remote Starter Wire.. with a switch..
And when i turn the key forward.. but not to start..
And i use my remote starter switch..
Car starts Beauitful
keep in mind .. i dont know why this is... but using the key to start the car.. used to work, then it wouldnt, then it used to work again... and then it didnt work.... but now.. it does work.. but makes extreamly bad noise's, so im going to continue to use the remote switch..
Anyone have any thoughts..
also.. my coil might be bad.. and the car needs a tune up, still.
Old Jul 12, 2006 | 01:23 AM
jstrdn90rs's Avatar
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
Sounds like a bad ignition switch..not a ignition cylinder(one key fits in) ..its located on top the steering column underneath the dash.You basically by-passed it with your remote starter.
Old Jul 12, 2006 | 05:35 PM
xklipze's Avatar
ur turning into my right hand man lol...
I have also thought about it being the ignition switch...
my problem is finding it.. but i bet i could.. i wonder if i could try to locate a picture of one. so it would be easier..
u know... there is a serious problem with my car it makes some CRAZY noise's when i try to start it.. like electricity exploding type stuff..
how much is a new ECM and a Ignition switch ? at auto zone ?
Old Jul 12, 2006 | 09:46 PM
jstrdn90rs's Avatar
I been on vacation the last week and been bored...this is my way of killing time cause you know I been wanting to go back to work soo bad.NOT!!
Dont know about the cost of an ECM ,but I bought one off ebay for 76 bucks and it was an AC Delco reman..its in the car as I speak and doing fine.Havent bought a switch in some time so cant help ya there.
Old Jul 13, 2006 | 01:41 AM
xklipze's Avatar
nice, u think it would matter if i grabbed them parts out of the junkyard ?
i dont think it would make a difference
Old Jul 13, 2006 | 01:47 AM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
go for a new ignition switch,
search for one in ebay
i saw one for like 15-20bux.
if its on ebay it could be available in local auto store too.
Old Jul 13, 2006 | 02:06 AM
jstrdn90rs's Avatar
Yeah dont skip on that one cause you might be headed back in there sooner then you think.
Old Jul 14, 2006 | 04:03 AM
xklipze's Avatar
tommorow or the next day....i buy the new ignition switch.. and i think its gonna be a quick install too.
it wouldnt hurt to grab a ECM from the junkyard , i dont think they will charge me too much, because im a "FREQUENT" lol
i been waiting for this paycheck too long...
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
