bigger valves
Old Jul 13, 2006 | 11:39 AM
Casey Butt's Avatar
Car: 1988 IROC-Z TBI
Engine: L04.3 = 305-310-336
Transmission: TH-700R4
Axle/Gears: 10-bolt, 3.42 posi
bigger valves
When moving up in valve size from 1.84" to 1.94" or from 1.94" to 2.02" is it necessary to have new seats installed or can the old seats be re-ground to the bigger diameter? I've heard conflicting opinions on this.
Old Jul 13, 2006 | 12:52 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
depends on the heads. Smaller chamber ones going up big steps, like 1.72-2.02 would probably need new seats pushed in. Otherwise, if you cut the current material, your valve will be sunk deeper into the chamber.
Going from 1.84-1.94 doesn't require it.
Fronzizzle
Feb 9, 2017 09:31 AM
Formula8r89
Sep 22, 2015 04:24 PM
87hellbird
Sep 14, 2015 05:08 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
