383 Stroker-Need Help
Old Jul 20, 2006 | 03:13 PM
snakebite09's Avatar
Car: 1984 Pontiac Firebird
Engine: 5.0L 305... its an LG4
Transmission: Th-350
I am planning on stroking my 89 GTA 350 to a 383 and wondering what other mods I am going to have to do to make this possible, anything helps.
Old Jul 20, 2006 | 03:24 PM
AC's Avatar
AC
Car: Used to drive a camaro
You'll want to think about larger injectors, larger exhaust and ECM programming. Those are the (3) things I could think of off the bat. How much power are you estimating? If it's alot and your using a manual tranny well then you know what I'm going to say there and if your using a 700r4 I'd recommend (not necessary but good piece of mind) is a tranny rebuild and shift kit.
Old Jul 20, 2006 | 04:36 PM
The engine builder says I should be getting around 410 at the crank
LT1Formula
Oct 8, 2015 08:34 PM
JSDaddy189
Sep 26, 2015 03:50 PM
