Very quick question
Old Jul 31, 2006 | 11:25 AM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Very quick question
Pushrod length checking is to be performed on the #1 cylinder @ TDC with the rocker tightened down right?
Old Jul 31, 2006 | 11:37 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
You should measure the pushrod length with a dummy lifter (I take the hydraulic plunger out and fill it with washers to get it to operating level).. Then set the rocker up.. Use a checking spring on the valve you're measuring..
Old Jul 31, 2006 | 02:04 PM
Got no time for that. I have a comp cams length checker, and my #1 cyl is at TDC on the intake stroke. Is this the point at which you would use the checker? I am getting a reading of 6.95 and it doesnt seem right.
Old Jul 31, 2006 | 04:09 PM
ede's Avatar
ede
if you have no time to do it right why are you bothering to ask how to do it at all? do it any way you like.
Old Jul 31, 2006 | 05:20 PM
jr. gearhead's Avatar
Car: 83 T-Top w/ 85 Z-28 and 91 RS parts
Engine: 377 (in progress)
Transmission: 700-R4 (unless i find a t-56)
Axle/Gears: from the Z
no need to use a dummy lifter, but i agree w/ the checking spring (much less tension). just snug it down like a normal adjustment and then measure it
Old Jul 31, 2006 | 11:14 PM
I had all the tools I needed, all I needed to know is what I asked in my very first question, but I found my answer elsewhere, and my checking was performed the right way.
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
